User | Kudos |
18 | |
5 | |
4 | |
4 | |
4 |
Quite frequently, I encounter a need to do something repetitive on clusters, which have identical elements. Sometimes, I use "Cluster to array" and then "Array to cluster" vi's, like in the example below:
Instead of doing this, I would like to use a kind of "For loop", which would be able to operate directly on clusters with identical elements. The loop would iterate already during the compilation (generating repetitive code for each cluster element).
Perhaps, the standard For loop connector might have something like an option "Iterate over cluster elements".
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Index-on-quot-arrayable-quot-clusters/idi-p/1472192
