| User | Kudos |
| 2 | |
| 2 | |
| 2 | |
| 2 | |
| 2 |
Common use case for Event Structure is to create a User Interface.
I would really like to see an Add Event Case called "First Run" under the Application category, as shown in the attachment.
- Makes it trivial to set up first run options/settings
- Executes before the timout begins counting
- Requires no elaborate code outside the event structure (usually messes up the code window a bit,) no code to generate pre-event triggers leading into the structure, no special handling of timouts using shift registers (all alternative methods.)
- Makes a clean place to always see what happens when the code first kicks off.
