| User | Kudos |
| 12 | |
| 12 | |
| 9 | |
| 8 | |
| 4 |
I think there is too much clicking around in the BD to enable/disable/configure node options. I'd like some sort of context sensitive menu that just automatically appears when you hover your pointer on top of any object in the block diagram. For instance when you right-click the Read from Text File primitive you get this context menu:
You can do a lot of things here it seems, but there are actually only 4 direct configuration points, namely the ones I've highlighted with a red dot. It'd save a lot of right-clicking and subsequent menu browsing if a configuration menu just appear when you hover over an object for a short amount of time (50 ms maybe, the exact delay must be figured out by the UI guys):
Hover for a fraction of a second...
...go ahead and configure the node.
a) The node configuration menu may not cover any of the object itself, thus you'll still have access to the entire object graphic if your purpose was interaction with that.
b) No menu should appear unless your tool is empty. No need to make the node configuration menu appear if you approach the object with a wire for a terminal for instance.
c) Advantages are (at least) no mouse-clicking necessary, no menu fly-out hunting, no grayed options that takes space, no duplicate/triplicate options that takes space, no configuration dialogs that doesn't add anything extra (how about all those Properties dialogs that just lets you edit the object's label in a fancy way, but you have to look, because a new property might've been added in this LabVIEW version?). Just an intelligently populated menu with only the configuration options that makes sense in this context.
d) Help text for each configuration item should be shown in the context help window when you move over each item in the list, possibly minimizing the need for opening detailed help.
e) The short delay from still pointer to menu emergence means you can still move your pointer around the BD without menus flying about everywhere, while the delay is small enough that the menu seems to appear almost instantly when you do hold the pointer still on top of an object.
I envision such a node configuration menu to appear for any node basically. One of the key aspects being that the menu is object and context dependent. For instance a subVI:
... or a tunnel on a While loop:
For some objects there might even be some key information available in this node configuration menu, information that is otherwise several clicks away. For subVIs such information could be if it is inlined, reentrant, has debugging enabled etc.:
Cheers,
Steen
