One of the quickest (and easiest to forget) methods to improve performance of your VI is to disable debugging. It requires a trip down the VI properties to get there, however. I propose adding a button on the BD alongside the other debugging buttons to Disable and Enable Debugging.
Jim, good point. So does that mean the button should be a temporary override, or a persistent setting? I might vote for a temporary override (reset once VI leaves memory), but I would not want a persistent setting on the toolbar. Honestly, I rarely disable debugging because I never think about it, and any benchmarking I do is going to be relative, not absolute. But if it were on the toolbar, I may think to use it more?
Great idea. In fact, why is the debug setting saved with a VI anyway? And why does it default to enabled? It makes much more sense to have debugging always disabled (i.e. VIs always saved with non-debug code), but VIs are recompiled for debugging if a button is pressed in those VIs you're looking at - they're necessarily open anyway. If the next version of LV was set like this, 90% of programmers would think "Wow - this version is SO much faster!!"
I concur but in the grand schele of thing, we need more.
Offer a column in the project explorer that allows doing it:
- per VI
- per Folder
- for All VIs
- add you own options here, like all dependent subVIs, etc
In particular, I see the need for "temporary groups" of debuggable VIs defined as a list (or in the column spirit of the idea above). Check it, uncheck it. Save it, modify it, etc, etc.
