Sdserlin
Disable Diagram Structure for a specific event case or sequence case
While the code within an event case can now be disabled with the disable diagram structure, it would be helpful and at times faster if a specific event case was able to be disabled with a single right-click selection.  This is a slight modifcation of the diagram disable feature, but a toggle off/on would be faster than dropping the diagram disable structure onto the specific event case and then disabling the specific code.  Better yet, make the ability to select multiple event cases at a time to toggle off and on in a single shot. Same thing should apply to sequences, and multiple case statements. You could even build a filter to save and control these multiple event cases by name within a right-click toggle selection save, disable, and retrieve selection.
3 Comments
altenbach
Knight of NI
Do you mean like this?
ouadji
Trusted Enthusiast
Darren
Proven Zealot
