I have two controllers under the same project . and both will run similar application. so i use same source code for both the controllers. and i don't want to disable auto deployment of variables. apllication is deployed controller one and it's running. after that if i deploy application to controller -2 unfortunately target settings Target 1 also deployed while deploying application on target 2 . it should be rectified
