When right-clicking on a VI in a class, there's an option to "Remove From Library". This option removes the VI from the library, but leaves the file on disk.
95% of the time that I'm removing a file from a class, I'd also like to delete it from disk.
The wording might need a bit of work, but it'd be great if there was an option to simply "Delete" or "Remove From Library and Delete".
(In the meantime, I'll continue to "Explore...", then "Remove From Library", then delete from my file system.)
