When the Icon view as added to LabVIEW, it was a decision to make this option be default for the benefit of new users. While there are definitely strong opinions on which is better (icon or terminal), overall the feedback from new users globally are that icons are preferred until they reach a certain LabVIEW proficiency and then the environmental option in Tools>>Options is turned off. The decision to have icons as default is still valid for our users. The ability to turn this off and that this option preference will be carried over via ini file if you upgrade LabVIEW appear to be logically solutions. The issue though of converting existing icons into terminals on a larger scale than just one at a time is something R&D is currently investigating.
The default LabVIEW environment option should not show terminals as an icon.
While some new users may consider this feature an intuitive method to bridge the gap between Block Diagram and Front Panel, it's clear that some might assume different functionalities for different Booleans.
I don't think I was even aware there are so many glyphs (and this image is not even exhaustive):
Some boolean controls *do* have different functionalities for their FP terminals. The Mechanical Action defaults to different things for different booleans.
Any Boolean can be changed to any one of the six Mechanical Actions (at the risk of breaking code if you have dropped Locals and choose a Latched option). Further, any Boolean can be customized to have non-default images for each of the 4 or 6 states. The glyph is potentially unreliable and misleading for any control that has been customized.
True. That doesn't seem to happen very much -- buttons tend to be latching, LEDs tend not to be, so definitely for the novice and mostly for the experienced user, the icon does provide differentiation. Having said that, if we back away from the associative icons, having a glyph on the FPTerminal that indicates the mechanical action I think would be useful. It is one of the aspects of seeing the icon that I like.
Or, having some text or the Mechanical Action glyph on the Context Help for both the FP Control and BD Terminal... I'm hesitant to start Bedazzling the FP Terminals. 😉
If it has an impact on how the "public behavior" of the node, I want the node decorated. That goes for configured express VIs, primitives with options and FPTerminals. Reading the diagram should tell you what the code is doing. I don't want to decorate with under-the-hood details (such as "is this node reentrant?"). Those are things that change how the node gets its job done, not what its job is. Mech action changes what its job actually is.
I actually much prefer the large icons myself. Since we use small object-oriented methods anyway, we never run out of screen space, and I find the large icons cognitively simpler to apprehend under these circumstances. I vote to keep the large icons the default.
