The NI Volume License Manager has a tool to create a volume license installer.
If you want to include Drivers you have to copy them to the installer folder _src\DriverDVD and then modify the nisuite.xml file (depending on license server you run)
There needs to be a simple way to say add NI disc to installer folder. Or at the end of creating the installer it could ask if you want to include other discs.
This should work for adding the driver disc and other extras like the Xilinx Compilation Tools, etc...
That way you can easily put together a full LabView Development install location for users.
