Make boolean logic functions that are already connected to the Loop Condition Terminal create a Stop Button by default:
What I currently do is build the code up to the point seen at the top, then right-click on the Loop Condition terminal to create my stop button. I then move it over and connect it to the OR.
Albeit it isn't too much of a hassle, I could imagine newer users being confused/frustrated trying to create a stop button off of the OR gate. Personally I find the process a bit annoying (I typically write several small example programs in a given work day and almost always use this).
I would like to see a Stop button created off of the first "tier" of boolean logic (including Compound Arithmetic) that is already connected to the Loop Condition terminal. This change, along with allowing a Boolean Function to Accept an Error Cluster, would make programming loops in the above way a much faster and more intuitive experience.
Any thoughts?
John Passiak
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
