User | Kudos |
18 | |
5 | |
4 | |
4 | |
4 |
If creating a reference to a .Net control you will observe that is reference type of ActiveXContainer is created which is sometimes confusing at a first sight.
Please introduce a .NetContainer (at least cosmetically at block diagram) for a better overview. If you are doing so, you could change as well the color of the ActiveX container with respect to the .Net container on the block diagram. If you have to change the programming interface, it would be much easier to spot where you have to do so.
