Dekay
Clean up Probe Window Graph
Status: Declined
Moved to CAR database: CAR 571556
In Probe Window, right clicking on the Graph of a probed waveform and selecting Visible Items/Graph Pallet allows you to zoom in on a portion of the graph.
However, the zoom button has been moved outside of the cluster, and can't be moved. Useful feature, but just needs a cleanup.
8 Comments
X.
Trusted Enthusiast
Trusted Enthusiast
Uh? Zoom button is fine on my version (LV 2013 XP 32bits).
Dekay
Mine's out of whack:
Anybody know how to fix it? It doesn't move, even with the program stopped. Something similar to edit controls, or??? The version is 2012, 32bit.
X.
Trusted Enthusiast
Trusted Enthusiast
I withdraw what I said. I was not using a "Waveform" probe, but a "Custom Probe" which I chose to be a Chart (I used a simple numeric as the source).
If I use a waveform as a source, and use the default "probe" for that, which is what you are displaying, then yes, even in 2013, that bug occurs.
Definitely a bug.
Darren
Proven Zealot
Status changed to: Declined
Any idea that has received less than 2 kudos within 2 years after posting will be automatically declined.
X.
Trusted Enthusiast
Trusted Enthusiast
This is not an Idea, this is a bug report and it is still active in LV 2015. Please fill a CAR at the very least!
Darren
Proven Zealot
X.
Trusted Enthusiast
Trusted Enthusiast
There is actually a related bug for Chart, as illustrated below:
Choosing a Custom Probes>>Controls>>Graphs>>Waveform Graph as a probe will maximize the graph size and present it "bare". You can (try to) show some additional tools (only AFTER it is executed once, which I suppose does not qualify as a bug but merely as a "feature"), such as Graph Palette or the Cursor Legend, but they will end up outside the visible area. Resizing the probe window doesn't help.
This is also true of XY Graphs and Waveform Charts.
Tested in LV 2015 64 bits.
ChrisStrykesAgain
CAR 571556 has been fixed in LabVIEW 2016. Please see the LabVIEW 2016 Bug Fix List for more information.
