As expected, the use of a Value or Value (Signaling) property for a button with a latch mechanical action will generate the error 1193 when executing this code.
Run this code ? Yes, the Run arrow is unbroken in this case. I suggest to break it... like when trying to write to a local variable of such a button.
Any idea that has received less than 3 kudos within 3 years after posting will be automatically declined.
