When your certification expires, do you instantly forget everything you knew? Of course not.
I think the Certifications should be tied to a LabVIEW version. That way, there's an "implied age" to one's Certification (if they haven't taken a newer one), but you are still allowed to produce the Certification on cards, job interviews, etc.
This seems like a good idea to me, however a quick check through other professional certifications and most seem to have an expiry date associated with them, and a recertification. Wonder what is the wisdom behind it.
While I like your idea, I don't think that expiry or not makes any difference to the light in which your proficiency is looked at. If you tell me that you were a CLD 4 years ago, but that certificate has expired, I will still consider you a credible LabVIEW programmer and keep in mind that you might not know the very latest in LabVIEW.
I might sound a bit pessimistic, but I'm just trying to see the other side of the fence to weigh this better. I still like the idea, nothing wrong with it. Kudos!
nagarajahc & vikramkumar, etc, I appreciate the comments. If you like the idea, remember to hit the Kudos button to the left of my "Rush" icon up there. That's how the Idea Exchange "works"
But these days you get a new labview version each year. And the differences between 2009 and 2011 are minimal for certification aspects.
Do you want recertifications every year? Even if there are minimal changes?
good old 8.x times 🙂 one version for several years.
