When you mass compiled, all VIs in the directory tree get recompiled. When you hold CTRL and SHIFT and click the run button on a VI, it forces a recompile of all VIs in the call chain.
However, when you CTRL-SHIFT-Run, all you SEE is a busy mouse; it would be really nice if you could get a popup windows (the same as when you mass compile) showing what's going on, and giving options to cancel... it would also be nice to be able to specify a log file and how many VIs to cache, same as with mass compile...
It could be the same popup with a different title...
