moderator1983
Bundle/Unbundle By Name function with 'Hide Full Name' selected by default
Status: New
Whenever I place a Bundle By Name (or Unbundle By Name) function on the block diagram, it is configured to Show Full Names. But while creating the cluster, I provide descriptive names to each element and so I want that every time when I place the Bundle By Name (or Unbundle By Name) function on the block diagram, by default it must be configured as Hide Full Names.
Unbundle function
I know, my wish is not what everybody else wants to have, so better solution to this could be a selectable option (perhaps categorized in Environment setting).
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
11 Comments
crossrulz
Knight of NI
Correct me if I'm wrong, but clusters don't have shortened names.  They just go by label names.  So first we would have to somehow define what the short names would be.  Seems to me like you just need to make the labels of your cluster elements be the short names in the first place.
GCentral
Darin.K
Trusted Enthusiast
He is showing a nested object with dot notation.  Short names only show the label of the control itself.
jcarmody
Trusted Enthusiast
Jim
crossrulz
Knight of NI
Ah.  I learned something today.  I can go home now!  I ddin't realize you could directly access subcluster items in the bundle/unbundle.
GCentral
moderator1983
Sorry for being less descriptive.
Please refer to the attached picture:
More Description
jcarmody
Trusted Enthusiast
I'd like it your way.  Perhaps the full name could appear in a tool-tip text when you float over it.
Jim
moderator1983
jcarmody:
I like your idea of having full name displayed in a tip strip... Smiley Happy
PWEC
 I just ran into this same issue, has it been implemented?
wiebe@CARYA
Proven Zealot
AFAIK, no. The idea would have been set to " Implemented", and it isn't.
AristosQueue
Proven Zealot
Not implemented. Honestly, I doubt it ever gets implemented -- just flipping the default would be a quick change, but I don't think that would be a good setting for a way too many users who use these dotted elements... I've seen too many mega clusters-of-clusters which have repeated elements over and over again. Adding it as an environment setting is obviously straightforward, but it's time that would be hard to justify the ROI.
