This is an extension of Darin's excellent idea and touches on my earlier comment there.
I suggest that it should be allowed to mix booleans with numeric operations, in which case the boolean would be "coerced" (for lack of a better word) to 0,1, where FALSE=0 and TRUE=1. This would dramatically simplify certain code fragments without loss in clarity. For example to count the number of TRUEs on a boolean array, we could simply use an "add array elements".
(A possible extension would be to also allow mixing of error wires and numerics in the same way, in which case the error would coerce to 0,1 (0=No Error, 1=Error))
Here's how it could look like (left). Equivalent legacy code is shown on the right. Counting the number of TRUEs in a boolean array is an often needed function and this idea would eliminate two primitives. This is only a very small sampling of the possible applications.
Idea Summary: When a boolean (or possibly error wire) is wired to a function that accepts numerics, it should be automatically coerced to 0 or 1 of the dominant datatype connected to the other inputs. If there is no other input, e.g. in the case of "add array elements", it should be coreced to I32.
