By default the front panel opens when opening a vi, and you need to toggle the view to get to the back panel. Although it probably doesn't make sense to switch the default behavior for all vis to open the back panel first, it would be nice to have an option to do this on a vi by vi basis. The main advantage of this case would be the removal of a second window (the front panel), that doesn't need to be take up desktop or taskbar space when only editing code. Closing the block diagram for a vi that has this option enabled would be equivalent to closing the front panel for those that don't (i.e. save prompting).
Note I found the same idea here, although mixed in with other elements.
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/LabVIEW-IDE-Overhaul/idi-p/952251#M1160
Any idea that has received less than 5 kudos within 5 years after posting will be automatically declined.
