DanyAllard
Be able to Find All Instance of VI and view VI Properties when the VI is in run mode
Status: New
It's append all the time that I right click on a VI when the VI is running and I need to find all instances but the option is not there. That could be very useful to debug the code.
An other option that could be very usful is the posibility of opening the VI Properties when the VI is in run mode.
LabVIEW ChampionArchitect
8 Comments
JackDunaway
Trusted Enthusiast
Same for Globals. You cannot right-click and use "Find Global Refs" or "Find Global Definition" if the VI is executing or reserved for execution.
DanyAllard
Good point Jack
Technico
I posted practically the same thing a while back:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/sub-VI-Icon-make-quot-Find-All-Instances-quot-also-ava...
My case was particular for the case where a file is read-only on disk, but someone commented that this is similar when the VI is running.
Maybe these ideas (and kudos) can be merged...
DanyAllard
Yes for a merge
TiTou
Trusted Enthusiast
The "find all instances" only finds instances in VIs loaded in memory, that's not very convinient... when the VI for which we want to find all instance is part of a project, we should see all instances in the project wether or not the callers are in memory.
my 2 cents
Epictetus
Antoine Chalons
AristosQueue (NI)
NI Employee (retired)
Right click in the project tree and choose "Find Callers". That will search for uses among all VIs in the project, even those not in memory.
JackDunaway
Trusted Enthusiast
AQ, yes, but there are just a few problems with Find Callers: Allow the Find All Callers Window to be Resized, and read my first comment point #2 on Open All Callers from Project.
TiTou
Trusted Enthusiast
Yes.
The point is that and when you have a project with 5000+ VIs (many of which are called dynamically), if the VI for which you want to find all callers IN THE PROJECT is opened, you need to use the "locate in project" before.
So a "find all callers in the project" option from the VI would just make life easier 😉
Epictetus
Antoine Chalons
