If You drag a tunnel of a loop, case structure or any other structure along the border over a corner, then
the connected wire becomes hidden behind the frame.
Sometimes, the wire looks alike it is connected to another wire instead - like in the example below.
I fell into that trap, because I've just seen the frame to the right and didn't expect, that the wire was
connected to the tunnel near the bottom.
Wouldn't it be great to break up the wire with a 90° corner and place it in the visible area?
More similar situations like this are posted in this thread:
http://forums.ni.com/t5/LabVIEW/wire-vanishes-behind-frame-of-case-structure/td-p/3221167
Re-opening because LabVIEW NXG has been discontinued.
