Is it possible to have a USB dongle license option rather than a registration key?
When the USB dongle is attached the user will have the full access to the Labview Version s/he has registered for, when it is not the program will only run in runtime engine mode. The advantage of this is that it would allow for system developers of multiple systems to be able to debug and test programs on the machines without needing to either have several licences or continually uninstall and reinstall labview from the machines everytime a change in the software is required.
At the same time, a USB dongle can only be used on one machine at any one time, thereby making it possible to ensure that there will not be more than one user of the same license.
I've seen this work for several small software companies as well as hardware companies with proprietary software. Why not for Labview?
Just a thought,
Karl
