moderator1983
Allow using standard shortcuts for 'Cut', 'Copy', 'Paste' and 'Rename' in LLB Manager
Status: Declined
Any idea that has received less than 4 kudos within 4 years after posting will be automatically declined.
While working in LLB Manager, please allow to use standard shourtcuts for following:
1. Cut (Ctrl + X)
2. Copy (Ctrl + C)
3. Paste (Ctrl + V)
4. Rename (F2)
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
6 Comments
moderator1983
Thank you
JÞB
Knight of NI
This could be almost as bad as "fixing" sequence locals by alowing them to looc like locals and globals (breaking datatype when passed outside a sequence)
Yup the LLB manager is cumbersome.  Why are you using an llb?
"Should be" isn't "Is" -Jay
crossrulz
Knight of NI
llbs are perfect for polymorphic VIs.  But that is about it as far as I have found.
GCentral
fabric
... They are also a pretty clean way to distribute dynamically loaded plugins.
Chris Virgona
moderator1983
@ : I don't prefer using LLB, but often that is the only format which is available from internet or may be someone else's previously written code or also as examples shipped with LabVIEW. My request here is to have standard shortcuts available within LLB manager, so that it will become little convenient to handle the same.
Darren
Proven Zealot
Status changed to: Declined
