User | Kudos |
4 | |
3 | |
2 | |
1 | |
1 |
Add a new button to the search results dialog called "Set Aside" so I can have multiple search results open at the same time. Put it near the bottom just below the search results. When you click it, it changes the title of the window to "Search Results - Set Aside 1". If you click "Set Aside" again when #1 is open, it will open "Search Results - Set Aside 2" ... and so on. This way you can have several different search results open simultaneously. I love the check mark feature in the search results, but it resets every time the search windows is closed or overwritten by a new search. Thus I lose my place if I want to make sure to check every instance of something but need to search again while looking at one item.
Duplicate of https://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-multiple-instances-of-quot-Search-Results-quot-...
