User | Kudos |
4 | |
3 | |
3 | |
2 | |
2 |
In the current implementation, charts increment along the x-axis and waveform graphs have the array index linked to the x-axis. The y axis is graphing the values.
There are many scenarios where this axis association should be swapped. However, we cannot do it without resorting to xy-graphs and jumping through flaming hoops, significantly complicating the data structures.
I propose a right-click option "swap axes" which would have the following effect, depending on the object:
Charts (waveform, intensity) would have the y-axis labeled "time" (by default), there would be an optional vertical scroll bar, and the data would run up (or down) with time (instead of left or right). Everything else would stay the same, same datatypes, data structures, same definition of chart history, etc.
Waveform graphs would have the y-axis tied to the array index of the data, while the value is tied to the x-axis.
Often, we want the data simplicity of a waveform graph, but swapped axes. One (of many) example application would be an intensity graph with a cursor flanked by a narrow vertical graph on the right and a narrow horizontal graph below (See image). These two additional graphs are used here to interactively show the intensity profile along the cursor lines.
Currently, it is not possible to use a waveform graph for the graph on the right. We need to use an xy-graph and do some data gymnastics. With this idea implemented, we could use a plain waveform graph with swapped axes and simply graph a plain 1D array sliced out with "index array". Wouldn't that be great?! 😄
Similarly, we could also allow this for xy graphs where it is not as important, but would simply swap the way the data is displayed (e.g. the imaginary part along X for complex data). This could be useful too.
The ability to swap axes should probably only be available at edit time...
