JackDunaway
Allow a quick "Timing Probe" for Timing Metrics
Status: Declined
National Instruments will not be implementing this idea. LabVIEW R&D has researched the concept of a quick timing probe and concluded that, for a variety of reasons, it would be difficult to provide a robust "quick" solution. One of the primary reasons involves difficulty in determining when timestamps are gathered. Timestamps gathered at the moment of probe execution happen when upstream nodes generate the data, NOT when downstream nodes consume them. This can lead to confusion about what is being timed. For instance, if a user is trying to time a node by putting a Timing Probe on an input wire and an output wire, it is possible that the Timing Probe on the input wire executes before other inputs are ready. The resulting delta between that input wire and the output wire may be longer than the time that the node consumed.
LabVIEW R&D continues to research this issue, and we are exploring multiple alternative solutions, including:
  • Node Probes, where you have a single probe that not only displays all the inputs and outputs of a given node, but also provides timing information of the node
  • Additional infrastructure within the probe mechanism itself whereby you can get information like the delta t between executions of any probes that have been created
For now, please see this forum post on Data-agnostic Smart Probes, which is a feature of LabVIEW 2016 and later that facilitates the implementation of a quick timing probe. Note that we have posted an example Timing Probe to that thread.
Typical question in development process: "How quickly does my code execute? What runs faster... Code A or Code B?" So, if you're like me, you throw in a quick sequence that looks like this:
AHHH! What a mess! It's so hard to fit it in, with FP real estate so packed these days!
We need this:
 Just like my other idea, and for simplicity's sake NI, I would be PERFECTLY happy even if you had to set up the probes during edit mode, and were not able to "probe" while running.
 As a bonus, this idea may be extrapolated into n timing probes, where you can find delta t between any two of the probes.
29 Comments
Enrique
Very nice suggestion. They way I was visualizing it is that when you right-click a VI or a piece of code that is enclosed (like inside a for-loop or a sequence), you have the option of a timing probe. Then that piece of code is highlighted similar to a break and you will see a small probe window.adding_timer.PNG
www.vartortech.com
JÞB
Knight of NI
As long as we are talking about a quick benchmarking method lets go one step further.  While timing probes are in memory automatically disable Automatic error handeling and debugging. Smiley Surprised
"Should be" isn't "Is" -Jay
shb
VI Box Probes from Saphir also contains timing probes (named chronograph). I really like them.
Install the package with VIPM or see first http://sine.ni.com/nips/cds/view/p/lang/de/nid/209756
Jokelnice
When can we see such ideas implemented?.
Ing. Jonathan E. Cruz Ortiz
ENERGÍA PROACTIVA S.A.S
Cel : (+57) 3173669343 - (+57) 3124451894
thutch79
I had the same idea, though I was thinking of it in a structure sense. I like the probe idea, but I thought maybe something similar to a case structure. You wrap it around the code you want to test. It has an output of time (ms). This would be a little more powerful in that you could time things executing in a loop and get all the times out. Probes would certainly be less invasive. The structure would just be a simplier representation of the same code we all use to test execution time today.
crossrulz
Knight of NI
thutch, I'm pretty sure you can do all of that with the Timed Loop Structure
GCentral
Darren
Proven Zealot
Status changed to: Declined
DavidGrimm
Like tic toc in matlab
