I like the idea but I'm just pointing out that since it is a primative there would probably need to be a way to do it on OS X and Linux as well as Windows. The Windows implementation seems to be already done but it would be up to the developer of the feature to figure out the best way for the other OSes. Any ideas on ways to do this on OS X or Linux anyone?
Well that's one of the big issues with the solution posted above : it is Windows only ; and I expect NI to not only add this option but also to make it multiplatform.
Along with this, I still want the ability to delete absolutely even if the OS has a recycling bin. Temp files created during a run should be able to be deleted directly, not sitting in a recycling bin waiting for restoration.
That would be just fine for me.. since I'm not the one in charge to deal with compatibility issue when down/up-converting from a Lv version to another :p.
There is absolutely no way to do this in a consistent way under Linux. The recycle bin on there is a pure desktop feature and accordingly different for each desktop manager (if at all present). And to make matters worse it is not even standardized between versions of the same desktop manager. To support such a feature under Linux is a 200% sure way to cause support issues from people complaining that it doesn't work on their flavor of Linux. As such this feature is very difficult to support in LabVIEW, unless the developers would decide to simply nerf it for the Linux version of LabVIEW.
Mac is also complicated but not entirely impossible. The APIs to do Recycle bin operations have changed several times during the course of MacOSX and the old compatibility APIs in the old Carbon and later Core Foundation were all depreciated and eventually removed. Only way to do it nowadays is through the Cocoa API but to access that you are almost obligated to write Objective-C code. Since NI only has very limited OS X support for multiple versions it is however doable.
