User | Kudos |
17 | |
5 | |
4 | |
4 | |
4 |
After applying my own subjective intellisense (see also ;)), I noticed that "replace array subset" is almost invariably followed by a calculation of the "index past replacement". Most of the time this index is kept in a shift register for efficient in-place algorithm implementations (see example at the bottom of the picture copied from here).
I suggest new additional output terminals for "replace array subset". The new output should be aligned with the corresponding index input and outputs the "index past replacement" value. This would eliminate the need for external calculation of this typically needed value and would also eliminate the need for "wire tunneling" as in the example in the bottom right. (sure we can wire around as in the top right examples, but this is one of the cases where I always hide the wire to keep things aligned with the shift register).
If course the idea needs to be extended for multidimensional arrays. I am sure if can be all made consistent and intuitive. There should be no performance impact, because the compiler can remove the extra code if the new output is not wired.
Several String functions have an "offset past ..." output (e.g. "search and replace string", "match pattern", etc.) and I suggest to re-use the same glyph on the icon.
Here is how it could look like (left) after implementing the idea. equivalent legacy code is shown on the right.
Idea Summary: "Replace array subset" should have new outputs, one for each index input, that provides the "index past replacement" position.
