If you want to fork a VI (start a parallel running VI), you have to load the VI reference, use the set control elements values method to initialize the controls of the VI, and than start it with the run VI method without waiting to finish. Quite complicate, if you ask me.
It would be cool, if there would be a fork VI method, which you call inside the VI you want to fork. The method copies the VI to a new place in memory including its actual running state. The new copy just goes on as it would without the fork, while the calling VI would get back the values of the ouputs, which they have at the moment of the execution of the fork method. Of course this does only work with reentrant VIs.
I can think of a LOT of applications which can use this!
Marc
CLD
