There is no way to get to the GObject property of "Position" in the dialog box. Its only available via property nodes, but if you want to statically set the control position, this is a pain.
I run into this when I have multiple, similar VIs that i insert and remove into a subpanel. in order to set the controls to be in the same position across the VIs, i have to use the property node for a 1 time use.
