acts2000
Add a property node (or any other method) for the font size of labels ("0"s and "1"s) in a "Digital Waveform Graph"
Status: Declined
Come up with a way to allow the user to increase the font size of labels ("0"s and "1"s in the image attached) inside a "Digital Waveform Graph".
3 Comments
Darren
Proven Zealot
Status changed to: Declined
EricLM
I'd like to see this reopened. Please expose this through a per plot property as a normal font property.
Even better, make a fixed width font the default.
Christina_R
Thank you for bringing this to my attention. While I can't offer a timeline, I agree that this configuration needs to be added to the Digital Waveform Graph in LabVIEW.
The numbers on the bus are currently always using the "Application" font. It is possible to customize the Application font using Tools»Options (Environment), but this will likely have undesirable side-effects.
Christina Rogers
Principal Product Owner, LabVIEW R&D
