Guruthilak
4-2-2-4 Connector pane while creating Subvi from Edit menu
By default, the a newly created vi will have the 4-2-2-4 connector pane, But when you create a new subvi from a main vi, LabVIEW generates Connector pane based on number of input and outputs. I propose the newly created subvi will also have the 4-2-2-4 connector pane and hence mainitaining uniformity through out.See the attachments. This saves the pain of chaging the connector pane, disconnecting and reconnecting the input and the outpus
Also if there any error terminals present in the subvi then the same should get connected to the bottom left and right panes and Path/refnum to the top left and right pane
Regards
Guru (CLA)
2 Comments
tst
Knight of NI Knight of NI
Knight of NI
This is a duplicate of this idea, which is already marked as being in beta - http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Create-a-proper-connector-pane-when-doing-Edit-gt-Crea...
___________________
Try to take over the world!
Laura F.
