LabVIEW FPGA Idea Exchange
About LabVIEW FPGA Idea Exchange
Have a LabVIEW FPGA Idea?
  1. Does your idea apply to LabVIEW in general? Get the best feedback by posting it on the original LabVIEW Idea Exchange.
  2. Browse by label or search in the LabVIEW FPGA Idea Exchange to see if your idea has previously been submitted. If your idea exists be sure to vote for the idea by giving it kudos to indicate your approval!
  3. If your idea has not been submitted click New Idea to submit a product idea to the LabVIEW FPGA Idea Exchange. Be sure to submit a separate post for each idea.
  4. Watch as the community gives your idea kudos and adds their input.
  5. As NI R&D considers the idea, they will change the idea status.
  6. Give kudos to other ideas that you would like to see in a future version of LabVIEW FPGA!
Top Kudoed Authors
Remove Stacked Sequence Structure from the FPGA palette
Why the "Stacked Sequence Structure" is still present in the FPGA palette? It has been removed from other targets palettes. I think it's better not be in the FPGA palette also.
André Manzolli
Mechanical Engineer
Certified LabVIEW Developer - CLD
LabVIEW Champion
Curitiba - PR - Brazil
3 Comments
Any specific reason you think using it on FPGA Targets is bad ?
I sometimes use it on FPGA (but mostly on host side) to reuse BD real estate during initialization - like setting FP controls/indicators and internal data to a known state. Also ensures everything in the frame executes before proceeding to next frame.
What I really don't like about it are Sequence Locals - clumsy and quite useless in my opinion. I would much prefer having support for Shift Registers to allow multiple frames access and update data in a large cluster ...
Well, it has been banned from Windows and RT. Why keep in FPGA since the only difference is how you (don't) see the code?
André Manzolli
Mechanical Engineer
LabVIEW Champion
