Benchtop Measurement and Test
High-Performance Test
Systems Engineering Software
It would be nice to be able to use logic operators on arrays in Single Cycle Timed Loops.
Adding to that, it would also be very nice when you can e.g. compare two arrays directly with =.
And not have a similar picture as in the left.
In former LV-versions this was by the way no problem... interestingly a step backward.
Lars, I don't believe LabVIEW has ever supported these nodes inside the SCTL, although it does outside. Did you see differently?
Thanks!
We'll be in touch soon!
