LabVIEW FPGA Idea Exchange
westgate
Improvements of Timing Violations Debuging
Status: New
i would suggest some Improvements to the Timing Violations Window.
  • Highlight the Whole Path with all Element and Wires in the Blockdiagramm when i click on Path in the Timing Violations Window.mark path.png
  • Highlight the Element on the Blockdiagramm which i clicked in the Timing Violations Window.
  • Give the Problem Window of the Timing Violations Window the ability to adjust its size i often have to scroll. (Can be seen in the Timing Violation Window above)
With kind regards
westgate
1 Comment
JCC_(SK)
I like this idea. My only solution is to label important function on block diagram (content menu Visible Items - > Label).
