While attempting to debug NI1483 issues, I found it necessary to make modifications to the NI1483 CLIP. In LabView 2014 and earlier, it's not possible to maintain your own IO Module CLIP directory. One must maintain all IO Modules within the IO module search path (<National Instruments>\Shared\FlexRIO\IO Modules folder ). This can be done by copying an existing IO module to a new path within the <National Instruments>\Shared\FlexRIO\IO Modules folder, then editing the *.tbc file to rename the "model" key. The main issues with this approach are the potential lack of administrator permissions and the difficulty of maintaining source control in a non-project related system directory.
The suggestion is thus:
1. Give the user an option to select the path of the IO module under the IO module Properties General Category (When Enable IO Module is selected).
That's it!
You can add the modified CLIP in the FPGA target properties like you would a user-defined CLIP. When you configure the IO module, the modified CLIP will show up along with the rest of the CLIPs.
