Some courses and learning paths on NI Learning Center may not appear on learner dashboards. Our team is actively investigating.
If you encounter access issues, please contact services@ni.com and include the learner’s name, email, service ID or EA number, and the list of required courses.
LabVIEW FPGA Idea Exchange
crossrulz
Allow Type Cast in FPGA
Status: New
We need a way to simply reinterpret the bits in our FPGAs.  I currently have a situation where I need to change my SGL values into U32 for the sake of sending data up to the host.  Currently, the only way is to make an IP node.  That is just silly.  We should be able to use the Type Cast simply for the purpose of reinterpreting the bits.
13 Comments
Intaris
Proven Zealot
Never mind, just re-read the OP. Move along, nothing to see here.
raphschru
An incredibly useful case of application for this "FPGA Type Cast" would be to flatten/unflatten a complex cluster into/from a fixed-size byte array for sending via TargetToHost/HostToTarget DMA FIFO. Currently this has to be done manually with lots of primitives.
Also, the argument that "high-level implementations are often inefficient, this would consume FPGA space at the expense of coding convenience." is false because reinterpreting the bits is purely a wiring operation and thus consumes no FPGA resource.
j_medland_css
I am just dropping by to say that for the specific example of converting a SGL to a unsigned 32-bit value is available in the NI Floating Point Toolkit.
NI LabVIEW FPGA Floating-Point Library Toolkit for LabVIEW - Download - VIPM by JKI
Being able to cast between numeric types of equal numbers of bits would still be handy generally and why is this toolkit not just installed with LabVIEW FPGA nowadays (only checked up to 2023 Q3 so maybe it is now in the FPGA module)
