LabVIEW FPGA IP Builder Community
Reply
Highlighted
IP Builder Optimization Example Files
The attached project and VIs can be used to replicate the optimization examples presented in the Using NI LabVIEW FPGA IP Builder to Optimize and Port VIs for Use on FPGAs white paper.
Starting with LabVIEW 2014, FPGA IP Builder is included as a feature of the LabVIEW FPGA Module. If you are using previous versions of LabVIEW, FPGA IP Builder is a paid Add-On to the LabVIEW FPGA Module.
To replicate the optimization examples presented in the white paper, you need LabVIEW 2014 and the LabVIEW 2014 FPGA Module. If you are using an older version of LabVIEW, you also need the LabVIEW FPGA IP Builder Add-On.
Senior Product Manager
Message 1 of 1
(3,319 Views)
Reply
