LabVIEW FPGA IP Builder Community
Reply
Highlighted
FPGA IP builder for Labview 2014
Hi guys, do you know how and if I can use the IP builder into labview 2014, I have only found a 2013 version which can not be used with the last Labview (2014).
Silvio
(3,546 Views)
Re: FPGA IP builder for Labview 2014
IP Builder 2014 is part of LabVIEW FPGA Module 2014. There is no separate installer for FPGA IP Builder. It's available when LabVIEW FPGA Module 2014 is installed.
(1,798 Views)
Thanks for the information! I have problem to import VHDL code in myrio application Do you have some functioning sample to link me? Thanks much.
SIlvio
(1,798 Views)
Hi Silvio,
LabVIEW FPGA has two mechanisms for integrating VHDL: CLIP and IPIN
They have different execution models. Code inserted into an IPIN runs
within the context of the LabVIEW FPGA generated VHDL code. It can share
clocks and synchronization with code written in LabVIEW FPGA. VHDL
inserted into a CLIP runs parallel to the LabVIEW FPGA generated VHDL. It
can use its own clocks.
This paper will explain more:
http://www.ni.com/tutorial/7444/en/
This paper has examples for both.
Jaidev Amrite
Product Manager
O +1.512.683.8036
jaidev.amrite@ni.com
To: Jaidev <jaidev.amrite@ni.com>
Date: 04/14/2015 09:51 AM
Subject: - Re: FPGA IP builder
for Labview 2014
Community
created by silvio.baccari in LabVIEW FPGA IP Builder Community - View the
full discussion
SIlvio
Reply to this message by replying to this email -or- go to the message on
Community
Start a new discussion in LabVIEW FPGA IP Builder Community by email or at
Community
Senior Product Manager
(1,798 Views)
Thanks Jaidev, can you attach a compatible vhdl file? I need it to test the procedure to import it in CLIP. Do you know if I can use matlab hdl coder to generate vhdl file?
Thanks in advance,
Silvio
(1,798 Views)
Reply
