LabVIEW Embedded
tow tank level control synchronizing
hy everyone;
I've porblem with synchronizing,i did tow tank ,when the fist tank is fully charged ,it shoud start to discgarge instantaneously ,but there is som delay by fous or six second >>how i can delete this dely >>please help,i will be so gratefull for you
(3,344 Views)
I have not looked at your code, but noticed you have posted the same question in 7 different places.
I would like to suggest that you will have better luck with responses if you post the question on the NI Forums.  http://forums.ni.com
However, since this appears to be schoolwork many may hesitate to provide a solution.
Good Luck.
Tech Advisor - Automation
LabVIEW 5.0 - 2020
(3,006 Views)
