04-12-2010 09:26 PM
05-04-2010 01:02 AM
11-25-2010 07:31 AM
So what was the source of such behaviour?
05-07-2011 06:00 AM
Re-read this post, currently no solution, ping labview-tcp no data is returned, the cable is good; also do not communicate through a router.
12-16-2011 04:49 AM
try:
ping "labview-tcp"
no slashes (/)
01-14-2012 01:45 AM
I had the same problem and now it's fixed.
The default complier options are to use a DHCP server. I suspect you do not have a DHCP server.
You can go to the compiler options and change the option to use a DHCP server and assign an IP address. This way you will have an IP address to use for the example program. (You will still not be able to ping "labview-tcp" as I suspect this name translation is soemthign also done by the DHCP server (or similar)).
05-05-2013 09:34 PM
also had problems to communicate between the card and the computer, I could rectify it by accessing the Project Connection prodiedades placing a static IP address
01-30-2014 08:04 PM
This procedure wishes to Ethernet data transmission between ARM LM3S8962 evaluation board and a computer, this process began when a client connection to the microcontroller, the server started generating random data and send to the client program (for this illustrative example only have paired with a client), if the client program disconnects or lost the link, the transmission stops and the microcontroller stay pending a new connection, as in previous demonstrations employ two routines the first is responsible for the generation of messages on the screen of the card and the second Ethernet communication, more https://decibel.ni.com/content/docs/DOC-35105
02-25-2014 04:01 AM
Thanks for this.
Also following thread is useful: http://forums.ni.com/t5/LabVIEW/Why-isn-t-DHCP-working-on-my-ARM-application/td-p/1502728
Here are some snaps to make it more clear. ( These are also there in above thread.)
Bhaumik
02-25-2014 08:27 AM - edited 02-25-2014 08:28 AM
Bhaumikdarji escribió:
Thanks for this.
Bhaumik
interesting, but the question is for a specific target LM3S8962, the answers are generic to a ARM microcontroller?
