Thank you in advance for taking time to look at my code. The problem is the FIFO is getting the data to the RT, but the RT FIFO is only transfering a small fraction of the elements to file. I seems to be some kind of data handling problem.
Here is a list of what is know. The list is also on the RT.vi to assit you in following the process. Although, it should not be hard as this is the best practice recommended by NI.
1. The FPGA is recording sending 27 values at 50000 S/s so in a one second burst 1.35 elements are sent via the FIFO. The FPGA is working correctly.
2. During operation, the Element Remaining 1 and 2 display values that make sense.
3. The element transfer in the FIFO for reading are recorded and totaled. The value is 1.35 mil as expected. So it appears data is getting from the FPGA to the RT.
4. The array in the line from the FIFO 1.Read to the RT FIFO Write shows 27k elements per the sample size defined in the RT FIFO Setup in the Flat File.
5. THIS WERE THE PROBLEM APPEARS -- The RT FIFO Read is only transferring 27 elements.
6. The data written to file ends up being only 1350 elements. Why?
If you need additional information please ask. I have copied this content on to the RT.vi, since my first attempt at a discussion post crashed.
Lloyd, S.
