12-22-2008 01:05 PM
Hi everybody,
I've made a test circuitboard with a Luminary LM3S1968 MCU and an Analog AD7738 ADC for testing SPI communications between a ADC and an ARM MCU in LabVIEW. Basic hardware tests (UART read/write, 'blink-a-led') went fine, but SPI communication is a problem.
Tomorrow I'll check the device for electrical problems, but suggestions for the LabVIEW program are greatly appreciated. Thanks for your time and happy holidays.
Paul
12-30-2008 01:05 PM
Hi Paul,
Thank you for your files. I will look over them and get back to you. In the meanwhile, please post back with any updates that you might have.
12-31-2008 06:09 AM
Hi Karunya,
Thanks for looking at my code. As for updates, here's what I've found out so far:
The trouble with SPI, especially ADC's that use it, is that you will always get a result (unless the part's dead, but even then you might get 0000 0000 as a result); making sense of the result is the hard part
Thanks for any help you can give me.
Paul
01-28-2009 08:21 AM - edited 01-28-2009 08:22 AM
Status update:
Well, my device works ok as long as it's using SSI port 0. I can send and receive commands, connected devices work well. As for SSI port 1; I'm certain it is a software setting that needs to be adjusted in the compiler, because I still can't access the port, no matter what hardware I use. To rule out hardware errors on my part, I've used the eval-kit for LM3S1968 from Luminary to read out signal levels while I was sending SPI messages. If I continuously send data over SSI0 with a 10 ms delay between bytes, I'll get this image on my scope for S0CLK (SSI 0 clock line):
If I try to do the same for SSI1 by changing the 'chip select' value from 0 to 1, the clock line stays low. Looks like something needs to be changed in the build options. Can anybody help and/or confirm this error?
Thanks in advance.
Paul
01-29-2009 09:57 AM - edited 01-29-2009 09:57 AM
Hi Paul,
This could be due to an issue with the IO configuration when using the LM3S1968; R&D is investigating. My apologies for our lack of responsiveness on this issue.
01-29-2009 05:09 PM
The driver only supports one SPI port, since that is all the 8962 has, but the 1968 has 2 SPI ports. You assumed (reasonably) that you could use a value of 1 to use the other SPI port. The VI should be returning an error when you use 1.
The SPI is such that you can use multiple devices with 1 SPI controller by using a different chip select line for each device. The driver does accomodate that behavior. So one possibility is that you use SPI 0 and use a different CS spec for the two devices you want to use.
You can specify the specific GPIO pin to use by the value you encode to the SPI input as follows:
[07:00] interface number (only 0 is valid now)
[11:08] GPIO pin number (0-7)
[15:12] GPIO port number (1-7, where 1=A, etc)
If the upper bits are all 0, then the default Fss pin is used for the chip select, and this should be considered the normal or default behavior. Specifying the GPIO line is a kind of advanced usage.
The other thing you can do is patch it by editing the SPI driver in your project to add support for the second SPU controller. We can provide the specific code to add if you like. It should not be very hard to do.
01-30-2009 03:11 AM
Hi Michael,
Thanks for your reply and explanation. I already suspected the 'chip select' option might have something to do with the #CS pin of many SPI devices. You could call it SPI multiplexing, and it's an option I considered as a backup solution (connecting #CS pins to GPIO pins and manually switch them). Your approach is bit different, though.
However, I would like to know how to edit/patch the SPI driver myself. Could you please post the details? Thanks.
Paul
01-30-2009 05:23 PM
The edits made in the attached files provide the second SPI port specifically on a 1968. This means the port pins are hard coded for a 1968. It might not work on other chips. More extensive changes are needed to allow it to work on any chip. The first SPI port (0) should continue to work just fine on the 8962 board or the 1968 board.
This is for the "Other" target. I assume that is what you are using since you have a 1968. If your'e still using the 8962 target then you need to modify the following instructions accordingly:
These two files can be replaced in the individual project as follows:
<projectname>\<appname>\LM3Sxxxx\Application\1.1\Drivers\SPI\ARM_SPI.c
<projectname>\<appname>\LM3Sxxxx\Application\1.1\System\Startup.s
Then completely rebuild the project.
If you do this it will work for your current project, but not new projects or if you ever do anything that overwrites the current project from the template. To make this change permanent and global, replace these files in the template at the following locations:
C:\Program Files\National Instruments\LabVIEW 8.6\Targets\Keil\Embedded\RealView\Generic\LM3Sxxxx\Template\System\Startup.s
C:\Program Files\National Instruments\LabVIEW 8.6\Targets\Keil\Embedded\RealView\Generic\LM3Sxxxx\Template\Drivers\SPI\ARM_SPI.c
I suggest that you rename the original files first so that they will not be overwritten. Please keep in mind that these changes are not tested, so back up your work first
09-22-2009 05:07 AM
I have a problom on reading data from AD7738.
Our Platform is Linux OS and the processor is mc9328mx2.
Can you tell me on what platform you are working.
09-23-2009 08:09 AM
We are facing some problem with reading data from AD7738:
The required configuration of AD7738 is:
1.) Continuous Conversion Mode.
2.) Conversion time 88h (Chopping enabled mode).
3.) Differential Channel with +/-2.5V.
4.) Dump Mode.
5.) Clamp Bit Enabled.
6.) 24 bit.
We have configured AD7738 in the following sequence with the respective Command Word:
The writing sequence is as following:
1.) Writing to Communication Register: 01h (I/O Register Address)
2.) Writing IO Port Data: 20h
3.) Writing to Communication Register: 28h (Channel Setup Register Address)
4.) Writing Channel Setup Register: 6Ch
5.) Writing to Communication Register: 30h (Conversion Time Register Address)
6.) Writing Conversion Time Register: 88h
7.) Writing to Communication Register: 38h (Mode Register Address)
8.) Writing Mode Register: 2Fh
9.) Writing Continuous Conversion
to Communication Register: 48h
The problem that we are facing are:
1.) The ready signal is always pulled high and it is never going low.
Can you suggest any solution to us.
