Hello, i want to ask if I can run startup fom Xfce Desktop Environment. I work with cRio-9038 with NI Linux Real-Time and embedded UI. In Xfce enviromet is located file here c:\ni-rt\startup\startup.rtexe but i don't know how to start the file. Is it posible run just after reboot like startup or can I do it somehow again in enviroment? Thank You for answer.
Yes, you can run startup executables with your RT VI front panels serving as the embedded user interface on Xfce, the same as building other startup RT EXE without a UI. Here's some helpful resources:
