LabVIEW Embedded
RT Application freezing after upgrade
Highlighted
Hello people,
I would like some help from you.
I've been developing an application for CompactRIO (Linux RT)  using Actor Framework.
Currently, I've been using LabVIEW 2015 SP1.
For a couple of days, I've tried to upgrade my project to the version 2018.
I did all the expected routine: formatted, installed new software, recompiled application and FPGA.
Then when I set to run, the application freezes, it uses all the memory and the cRIO becomes unavailable.
As far as I know, it is something with the application, but it reports no errors, it compiles and everything. I've tried to disable some actors, but so far nothing.
Prior to that, the application was running very fine in 2015 SP1.
Could someone point me where to look in the system (logs, etc...) and maybe find this incompatibility in my code?
Thanks.
Felipe Pinheiro Silva
Follow my blog for LV content!
(1,789 Views)
Highlighted
Hey Felipe,
My first guess would be mass compile your entire project.
Could you give it a try and then deploy your project one more time?
Cheers,
Felipe Flores
Applications Engineer II
National Instruments Brazil
(1,756 Views)
Highlighted
Thank you for the hint Felipe, but it was the first thing I did.
Unfortunately, it did not work, but I'll keep looking into this.
(1,742 Views)
Highlighted
Accepted by topic author felipe.foz
After changing some classes that were implemented by-ref to by-value I was able to upgrade without having freezing episodes.
Thanks.
(1,575 Views)
