Johannes,
The Blackfin lwip stack expects a DHCP server to assign it an IP, you cannot just connect a crossover cable between your computer and the EZKIT (unless your computer happens to be running a DHCP server). Connect your computer and the EZKIT and your computer to a router/switch so that the DHCP server on it can assign IPs to both. Also, you appear to be using the code from the example called Print EZKIT IP Address.vi. I recommend putting this code into a while loop with a wait.
Message Edited by Michael P on 07-27-2006 10:57 AM
Michael P
