I am trying to read a load cell with a 9237. I am using FPGA not Scan. I am unable to find any information on how to calulate the modules output to convert it to pounds.
I know my module, wiring and load cell is good. I was able to get good readings using an USB device with the module and load cell, see the image below for MAX settings.
Using the below forumal and the load cell calibration sheet I can get the correct pounds, but using the modules output I don't get the correct values.
(AO_Reading * FullRange) / (Sensitivity * ExVolt) FullRange = 100, Sensitivity = 0.003, and ExVolt = 5
