LabVIEW Embedded
MCB 2300 email
I have created a simple email VI which works in PC based LabVIEW.  It gives strange error results when I deployed it on the MCB2300 board.  Did anyone encountered this problem?  Please find the attached files.
(7,393 Views)
Accepted by Jaggs
First issue noticed in your block diagrams is the EOL constant, which is CR in LabVIEW for ARM
#define SSEOL ‘\r’ in CCodeGen\include\os\rtx\LVDefs_plat.h (seems to be a Mac:)
Modifying it might help, but I don't know how this affects other modules.
Do not think to replace EOL in block diagram with a "\r\n" string constants because code generator will write SSEOL in the C files for any two characters string constants \r\n. A solution could be writing constant such, e.g. "\r\n.\r\n" for end of message.
The error shown in your image is not so strange - it’s a corrupted heap memory error. Perhaps there is an improper interface between LabVIEW strings and zero terminated C strings. Try to add a NULL at the end of the server address (i.e. "server01.iacontrol.com\00" , if you select Code Display for that constant, BTW-perhaps the domain is iacontrols).
Few questions are looking for answers before going further:
Does the board connect to the server? (put a CCG Error Handler.vi after TCP Open Connection and watch the error in runtime)
If the connection is established, how many packets are sent/recv before an error occurred? (e.g. put a One Button Dialog after TCP Read).
If the connection is not established, can the board connect elsewhere? Which versions are you using? (LabVIEW and MDK-ARM)
P.S. It is fair to wait for "220" before transmitting "HELO"
(7,368 Views)
Hello Jaggs,
We are going to need a little bit more info.  Can you answer the questions Nic posted.  As well, when exactly is this error occuring?  Is it during the deployment process or right after the program begins running?
Jon S.
LabVIEW NXG Product Owner
(7,354 Views)
I am wondering if you received any message from Email@system.com
(7,308 Views)
No, it is not working.  I have upgraded my labVIEW version to 2009 and now I not able to create build.  I will try on another PC.
(7,301 Views)
Finally got it solved by modifying the LVDefs_plat.h file.  I am not sure if this is the final accepted solution or will there be a CAR for this?
(7,228 Views)
