06-07-2007 10:31 AM
06-11-2007 03:43 PM
Try these steps:
1) Disconnect your computer from your network.
2) Connect the crossover cable between your computer and the Blackfin EZ-Kit.
3) Assign a static IP address to your computer. If you don't know how to do this, follow the directions at the following Microsoft Website:
https://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/sag_tcpip_pro_manual...If you don't know what numbers to fill in while following the directions, use the following settings for your computer.
IP Address: 10.0.0.1
Net Mask: 255.255.255.0
Gateway: 10.0.0.254
4) Start LabVIEW and open your project.
5) Configure LWIP to a static IP address. To do this, open the Build Spec dialog in LabVIEW and click on the TCP/IP tab. Enable lwIP and uncheck Use DHCP. Fill in a IP address.
If your computer is setup with the above settings, the following Build Spec Options can be used for LWIP:
IP Address: 10.0.0.2
Subnet Mask: 255.255.255.0
Gateway: 10.0.0.254
06-13-2007 10:32 AM
