LabVIEW Embedded
How can I convert QT project in Labview application?
I would like to convert my application in Labview application or Vis. I created my application with help of Qt and C++. How can I convert QT firmware  in to labview class or Vis.
I know if my own c++ code then I need to C warp and dll file use with help of  share library or call library function node.  But I have issue with Qt firmware code. Is it any way to access the Qt project firmware in to lab view.
Any one please give me direction?
Thank you.
(3,692 Views)
There is no way that I'm aware of integrating a Qt project directly into LabVIEW. Your best bet is probably going to be to create a DLL from your C++ code then, as you have already said, call that DLL using the Call Library Function Node.
Applications Engineering
(3,655 Views)
