LabVIEW Embedded
Embedded / Real-Time LabVIEW -- Porting VIs from cFP to cRIO? Cross-posted to otehr boards.
Highlighted
Has anyone ported a real-time VI originally targetted to cFP to install on cRIO?
I have an older control program, main VI and subVIs built in LV 8.6 and run on a compact FieldPoint controller.
I would like to be able to use much of it on a cRIO-9036 or something similar.
I am wondering whether LabVIEW (2015 or so) will do the work for me.
Thanks in advance.
(2,456 Views)
Hi Dave_Karon
While there are no tools that I know of that will do the work for you, I have found this white paper that goes over how to transition from cFP to cRIO. While this guide isn't all-inclusive, it should help to explain the basics and point you in the right direction for additional resources you might need to update your code.
Let me know if there is anything else I can do to help you work through your transition!
Andy F.
Applications Engineering
(2,427 Views)
